How do you finish the finger board?
Ukulele discussions
Michael Cyr
Post by Michael Cyr »
I'm building a ukulele and it is my first build with frets. Usually i will spray a finish on when everything is finished and tape off the parts i don't want finish on but frets can not be taped off. So what is the most common method around this? I'm not their yet but trying to plan ahead and get it right. Thanks, Mike
Re: How do you finish the finger board?
For me it depends on the wood used. For rosewood, osage orange and cocobolo I don't put any finish on it. I tape off the fret board near the headstock, and spray the neck upside down to avoid getting any finish on the fret board. For maple I spray the whole thing, and scrape the finish off the individual frets.
I think some folks put some type of oil on the unfinished boards, but don't know which.
I don't normally finish my fretboards, but when I do, I spray a few coats of lacquer on before fretting. Makes for a clean job during fret installation.
Michael Cyr
Thank you Peter & Barry, i originally googled finishing a fret board and found mostly people applying a wipe on finish. After Peters reply a looked up scrape frets clean and everything opened up for me from using a penny or nail head to using a fret guard. I found something that will work for me perfect. Cut a soda can into 2 strips, lay them down alongside the fret and tape the two ends and you have an exact fitting fret guard. Laying a coat of lacquer down first is a good idea it allows me to sand the first coat smooth after the grain is raised and all other coats will lay down nice. Thanks
I forgot to mention that I have used wipe-on finishes on fretboards too. I have used Minwax Wipe-On Poly.
I think I didn't get my main point across. You don't need to apply finish after fretting. In fact, you will just make more work for yourself. Apply your finish before fretting but keep it fairly thin. Then install your frets and do your fret work. Obviously you will need to keep the fret work from scratching up your finished fretboard, but that can easily be done by covering it with masking tape.
Return to “Ukuleles”
