The "Local Materials" Challenge
The "Try Something Different" Challenge is closed.
Bill Snyder
Re: The "Local Materials" Challenge
Post by Bill Snyder »
Phil, if you look in the sub-forum you will see threads about several builds chronicalling their progress/
phil chestnut
Post by phil chestnut »
OK I wonder where they where hiding. thanks
Post by Charlie Schultz »
Hi Phil,
Here's a direct link: http://www.mimf.com/phpbb/viewforum.php?f=27
If you're at the "Board index" (top level), you should see the subforum "The Local Materials Challenge (now open)" listed under the "Challenges" forum. If you're in the "Challenges" forum, you should see a framed box towards the top (above the Announcements) with the text "The Local Materials Challenge (now open)" and "Here is where you put your entries". Hope that helps.
Andrew Porter
Post by Andrew Porter »
Been away awhile but I thought there were individual threads for each build, but now I can't find them.
Hi Andrew- see the post right before yours for where to find them.
Andrew Porter
Well I must be digitally challenged. I can't find the individual threads except by using you link above( viewforum.php?f=27 ) :?:
Well, subforums don't exactly jump out at you. In the picture below, you would click on the text "The Local Materials Challenge (now open)".
Andrew Porter
Of course as soon as I post I found out how, but thanks for answering :roll:
Tristan Williams
Post by Tristan Williams »
Charlie, to clarify, "midnight (server time) Sunday, May 20th" - is that the midnight at the start of or at the end of Sunday? ie if one were to go to bed promptly at that time, and slept for 8 hours, would you be waking up on Sunday or Monday.
I meant midnight as in the end of Sunday. You'd wake up on Monday.
Tristan Williams
Great, thanks :D
Tristan Williams
What timezone is the server in, anyhow? Eastern Daylight Time?
Jim McConkey
Post by Jim McConkey »
US Central Time
Jeff Mills
Post by Jeff Mills »
Geeze I own a sawmill and have wood out the ying yang :roll: is wild black cherry and walnut good for a solid body bass?
Yes, it's good stuff to use.
Chris Reed
Post by Chris Reed »
Charlie Schultz wrote:At the end of the challenge, all those who *completed* their instrument, plus staff, will vote on their three favorite instruments, and judging criteria will be left entirely up to you.
I saw the headline "Voting begins", but I can't find where/how to vote.
Also, it might be sensible to modify the approach above, as I think there were only three finishers! Presumably we shouldn't vote for ourselves.
Ok, sorry for the delay. Congratulations to all who participated, even if they did not complete their instruments in time.
There were 5 completed instruments and we'll go with the previously stated rules. So for those who completed their instruments (and staff), please send me a PM with with your choices for your top 3 instruments. David and Pat, since you both completed two instruments, you may vote twice!
Here are the choices:
- David Frasetto's lap steel ($60.19) http://www.mimf.com/phpbb/viewtopic.php?f=27&t=613
- David Frasetto's Gottan ($19.02) http://www.mimf.com/phpbb/viewtopic.php?f=27&t=702
- Chris Reed's Yew Uke ($33.94) http://www.mimf.com/phpbb/viewtopic.php?f=27&t=654
- Pat DeGreve's OM ($96.23) http://www.mimf.com/phpbb/viewtopic.php?f=27&t=622
- Pat DeGreve's LP Jr. ($94.10) http://www.mimf.com/phpbb/viewtopic.php?f=27&t=623
And yes, you can use one of your votes for your own instrument.
I also set up a poll for the general membership for a "member's choice" award, see http://www.mimf.com/phpbb/viewtopic.php?f=16&t=825
Return to “Challenges”
